Rapracing
- 0
- 16
- Western Pennsylvania
I went out and started the 002 to let it run for a little this morning. I went back after about a half hour and noticed that I had a minor oil leak from the canister seal. I shut it down and replaced the seal. When I started it back up the leak was worse
so I had to shut it back down and fix that. At that point I was down too low on oil so I added some. When I restarted it the voltage and Hz jumped up and dropped completely off after about 15 seconds. I shut it down and repeated start up and had the same result. I shut it back down, said a prayer and started it up and they have held now for about 15 minutes.
Do I need to be concerned?
What might have caused it to do that?
Bob
Bob
