Noise when accelerating?
Dpas1973
13
New Jersey
So today I noticed when accelerating I hear what sounds like a quick rubbing noise from the middle of truck. It’s a 4 speed. Looked underneath don’t see anything leaking from trans or transfer case. Checked trans fluid was on the money. It only makes this rubbing noise when accelerating then goes away in a second.
DREDnot
589
Phoenix, AZ
If you dont see anything obvious underneath, Grease your u-joints. Most likely cause of weird sounds on acceleration. Grease may be too late, though. You may need a new u-joint already
Dpas1973
13
New Jersey
I just jumped my a&e terminals on the Tcm and I’m getting fault code 37 I believe. Flashes 1,2 3 times then 3,7 three times then 1,2 2 or 3 more times what needs to be replaced with a 37 fault code?
Action
1,564
East Tennessee
Don't drive with your left foot on the brake pedal. Or make sure the brake lamp switch is properly adjusted.
