dm22630
- 42
- 0
- Front Royal, VA 22630
Two days ago my blinker would work only if I would first put the left hand signal on, then shifted it up to right hand or 4 way.
Yesterday.....no blinkers or 4 way.
Today....
Unscrewed the turn signal switch on the steering column, plugged in a different signal switch.....still no blinker.
Then I checked grounds.....well, the one ground I could find, which was on the generator.....it was completely disconnected (broken)....I replaced it with a spare from another truck.....still no blinker.
Then I finally found the signal relay that was hiding from me. All looked good, no loose wires. I will pull one from another truck tomorrow and switch them to see if that is the problem.
If not, what else could it be?
Thanks!
Today....
Thanks!
