PA NOS Hardware, Copper, Brass, Airlines, Fuel Lines, etc
country
394
Feasterville, Pennsylvania
More here www.easternsurplus.net
9M-1972 | Brake System Air Line Exhaust Fitting 45 Degree Pipe Elbow M939A2
NSN #: 4730-01-300-4091
Part #: 12-12 140339B, 20511217
$5.00
COM-5738 Brake Wheel Cylinder Bleeder Screw M35A2 M54A2 M809
COM-5738 | Brake Wheel Cylinder Bleeder Screw M35A2 M54A2 M809
NSN #: 2530-00-287-8252
Part #: 7539268
$4.00
SP-1888 | 4730-00-805-3450 Branch Tee Male for Rotary Vacuum Pump Unit NOS (4).JPG
HM-757 | Branch Tee Male Fitting HMMWV
Branch Tee Male for HMMWV 1 1/4 Ton
NSN #: 4730-00-805-3450, 4730-00-266-2647
Part #: 5936233
$3.99
HM-908 | Brass Barbed Union Tee Hardware HMMWV
Brass Barbed Union Tee for HMMWV 1 1/4 Ton Trucks
NSN #: 4730-01-476-0850
Part #: 12339973-3
$0.95
ALL-7470 | ALL-7470  Brass Fitting 38 Inch by 38 Inch Sold Per Lots of 10 (2).JPG
ALL-7470 | Brass Fitting 3/8 Inch by 3/8 Inch Sold Per Lots of 10
NSN #:
Part #: 20511310
$4.00
COM-5735 | Brass Tee Fitting 1/8 inch Pipe x 1/4 inch Hose OD HMMWV
NSN #: 4730-01-192-8086
Part #: 12339969 , 1077X4
$3.00
COM-5173 | 4730-00-540-2745 Brass Tee Fitting, 3 Way for M915A Airlines and M939 Series Fuel Tank Supply and Return Lines. NOS (6).JPG
COM-5173 | Brass Tee Fitting Three Way Fuel System
Brass Tee Fitting Three Way for AM General M915A1 Airlines and M939 A1/A2 Series 5 ton truck Fuel Tank Supply and Return Lines
NSN #: 4730-00-540-2745, 4730-01-095-2034
Part #: 888
$3.25
COM-5986 | 9/16 Inch Flat Washer Common Applications
NSN #: 5310-00-809-3079
Part #: FF-W-92, MS27183-19
$35.00
SP-1920 | 90 Degree Brass Elbow Fitting
90 Degree Brass Elbow 1/4 Pipe Thread (NPT) Barbed for air hose fitting
NSN #:
Part #: 12460304
$3.85
SP-3059 | 90 Degree Elbow Steel Pipe Hydraulic Fitting ½” JIC Male to 3/8” NPTF Male
NSN #:
Part #: 2501-08-06-4
$10.00
COM-5995 | 45 Degree Grease Fitting Lot of 100 Fittings Common Application
NSN #: 4730-00-172-0028
Part #: MS15003-4, 004860V003, 0915274-5
$20.00
SP-3057 | 45 Degree Steel Elbow Swivel Hydraulic Hose Fitting 1-1/4" JIC Male x 1-1/4" JIC Female
NSN #:
Part #: 6502-20-20-4
$14.00
COM-5768 | 45 Degree Street Elbow 3/4" NPT Male x 3/4" NPT Female Brass Pipe Fitting
NSN #: 4730-00-541-0793
Part #: 75167
$2.50
SP-3073 | 3/8 Male Inch Pipe x 3/4 Inch Tube Brass Elbow Commercial Fitting
NSN #:
$3.00
COM-5766 | Blind Rivet Nut Insert 5/16-18 UNC Steel Knurled
NSN #:
$0.10
HM-3523 | Body Wiring Harness Coupling Nut HMMWV
NSN #: 5975-00-697-7769
Part #: 7527645
$5.00
COM-5303 | Bolt, Hexagon Shaped Head - common Hardware
Hexagon Bolt For Common Application
NSN #: 5305-01-156-5108
Part #: M-25-20010
$9.00
COM-3152 | Banjo Brake Fitting Line M54A2 M35A2 M809
Banjo Brake Fitting Line Fits M35 A2/A3 Series - 2 1/2 Ton
NSN #: 4730-00-278-5812
Part #: 5298521
$4.00
9M-2004 | 9M-2004  Adapter Straight Pipe to Tube Front Winch Pump M939A1 M939A2 (2).JPG
9M-2004 | Adapter Straight Pipe to Tube Front Winch Pump Sold Per Lots of 5 M939A1 M939A2
NSN #: 4730-01-090-4919
Part #: 12255651-2
$10.00
COM-6046 | COM-6046  Adapter Straight Pipe to Tube Fuel Line Fitting Common Application (4).JPG
COM-6046 | Adapter Straight Pipe to Tube Fuel Line Fitting Sold Per Lot of 10 Common Application
NSN #: 4730-00-620-6904
Part #: J514, C5205X5X4, MS51500B5-4
Call for details
