drewmech
- 29
- 18
- Tulsa Oklahoma
Plan is to pull the NP208 transfer case and hook it up with a NP203/205 doubler. I know where to find the lower gears for both transfer cases but I was wanting to up the gear ratio in the HI range in an attempt to gain alittle bit better cruising speed at lower engine speeds when not on the trail or towing. Basically use the hi range of one of the transfer cases like an overdrive gear without the hassle of having to switch to a 700R4 tranny. Anyone ever heard of this or know some where I can look? Or am I just asking a dumb question?
