bigburb11
- 0
- 0
- Detroit, MI
Hi everyone,
I'm new to the forum and to my M1008. They are both AWESOME!!!
The M1008 has what appears to be factory dual exhaust on the 6.2.
I've always been told that the brace (bar) running from the passenger side of an NP208 (attached by two large bolts running into the transfer case) to a bell housing bolt on the back of the engine is a MUST... this helps avoid cracking the transmission case under hard use due to torque reaction of the drivetrain.
My truck doesn't have the brace... the dual exhause seems to make package space for the brace difficult.
First, I want to confirm that these trucks came with dual exhaust from GM. Second, I want to check and see if the M1008 should have the transfer case brace installed from the factory (maybe someone took mine off and tossed it).
Thanks for any info available!
