NP420 transmission into 1963 M37; shifter rod hits the bottom of the dash in 1st gear
OutpostM37
50
Goldfield, Az
Someone I am sure has come across this malady. I have a 1963 M37 with a fresh stock 230 cubic inch flat head strait 6 that I have just installed into the engine bay. The correct transmission for this vehicle has been acquired. As I try to install the transmission, the stick shift will contact the bottom of the factory M37 dash board when shifting it into 1st gear. I have removed the transmission for shifter modification. The engine, bell housing, and frame of the vehicle are all factory, no mods. Researching the NP 420 transmission, I see that there were several variation of the "tower" (stick shifter).
Has someone rebuilding an M37 experienced this and what was their correction?
Should I bend the shifter, or cut and weld it shorter?
When I purchased the vehicle, it had an older style four speed with the shifter tower closer to the center of the transmission and a hole cut BEHIND the original opening in the floor board. See pic. I have a fresh floor board, and the correct for year(?) transmission for this '63 vehicle. M37 floor boards.jpg
Sgt Jiggins
Potato Peeler
206
Lynchburg, VA
You might drop a message to Ferroequinologist. He has (had?) the NP420 I took out of my '51 M37 20 years ago. If nothing else, he can send you a pic. I'll post a pic of the shifter from it shortly in case it helps you.
When I went to it's cousin, the NP435 (synchronized, otherwise pretty much the same), I too had the situation you have with the shift knob. I wound up heating it in the middle and bending it to fit. It lasted the 18 years I drove it that way before I sold it on just recently. I'm sure it'll still be working just fine after you and I are long gone from this planet.
SJ
nattieleather
143
Cleveland, OH
Made this from the original "highboy" stick shifter.
Lots of room for the nitrous bottle now.........
I know that is just a tongue in cheek statement, but I triple dog dare ya to hook up nitrous and post both pics and video....LOL!
Good job on the shifter should give you lots of easy shifts going forward.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Or just buy the correct shifter from Vintage Power Wagons and be done with it.....
