NSN 8340015139655 manual?
SandBar
Full Time Patriot
756
231
GA/FL
I am looking for the manual for NSN 8340015139655, any help greatly appreciated.
The description is:
AAR Mobility Systems 15KW diesel generator, trailer mounted, Powered by a Lister-Petter 4cyl diesel engine. Includes a Nordic Air Inc. ECU mounted on rear of trailer, 8 ton ECU, 96,000 BTU/HR model 2K36AF6A-M/M, 208-230V/3PH/60HZ with electronic temp control. Storage box mounted on front. Storage box contains flexible duct and cables. Single axle trailer mfr by C.H.I. Mobile Systems.
Specifically I am looking for the battery requirements and fuel filter part number.
bikeman
501
Ft. Bragg, NC
NSN only points to this for me: DHS, 8 TON ECU, 96,000 BTU/HR, GREEN, 208V/60HZ, SKID MOUNTED, FORK LIFTABLE, TO BE USED WITH DRASH SHELTERS MANUFACTURED AFTER JANUARY 2003.
I can't find a TM Associated with NIIN 01-513-9655
I'd say you need to find a different NSN for the entire item.
Poccur
110
Roanoke, VA
If it is the unit Stonepicker1 showed then they are up for auction and one of the power panels showed this:
http://www.govliquidation.com/shared/auction/images/photos/62195/62194981.jpg
That appears to show a DC meter that tops out at 16VDC..based on that I would say a 12V system. Odd, it most mil stuff is 24VDC as I am sure you know. Got any pics of the engine bay of yours?
Also, what model Lister is the engine? We should be able to figure out the fuel filter from that...maybe...
