NSN for HMMWV parts, where to find?
EdMontana
TN
Is there a TM with the NSN part #'s for HMMWV?
Looking for the NSN for the standard windshield glass, RT and LH
187
Youngstown, OH
Try:
9340-01-185-3757
Standard laminate, I believe is reversible for both sides??? Not sure though.
Also the window seal:
9340-01-209-5997
EdMontana
TN
Try:
9340-01-185-3757
9340-01-209-5997
The standard is actually a two piece (front, void, back) sandwich glass and seems like to be reversible for RH or LH sides , ....I did not find any NSN for parts on the site listed manuals, thanks!
steelsoldiers
3,968
Charleston, WV
Hmm, my fault. I'm not sure why we don't have the 24-P manuals on the site. I will get them uploaded asap along with a few others.
papakb
1,183
San Jose, Ca
J,
Clicked on the link above and it takes me to a different page every time, none of which have anything to do with HMMWVs. Have you been hacked?
Kurt
papakb
1,183
San Jose, Ca
Ed & depdog,
Working on HMMWVs without the manuals can be excruciating at best. There are standards for military technical manuals numbering but over the years they have changed so keep checking for current standards,
TM9-2320 indicates a technical manual (generic to a vehicle)
TB9-2320 indicates a technical bulletin (specific notification)
MWO indicates a maintenance work order (modification)
SB would indicate a supply bulletin
LO would be a lubrication order
Technical manuals specifically for the basic HMMWV start with TM9-2320-980-
The level of maintenace is then indicated by the last numbers:
-10 is an operators (drivers) manual
-20 is a unit level maintenance manual
a -20P or -24P manual would be a parts manual for this maintenance level
-30 or -34 is an organizational maintenance manual
a -30P or -34P manual would be for parts at this level
-40 is usually a depot level manual
If you have a -35 manual it will have a suffix like -35-1, -2, -3
each one of these is geared toward a specific proceedure like installing a different radio set.
Hope this helps
86humv
496
Texas
Try:
9340-01-185-3757
9340-01-209-5997
That is correct numbers and is reversible.
Same as civi glass.
Its in Tm9-2320-280-24p-1
Fig. 225 , item # 55, 54
Glass....12339514
Seal......12338860
