Southern Krawler
- 3
- 8
- El Paso,Tx
Hello everyone I started working on my M920 today after almost 2 years of procrastinating . The previous owner disclosed it had engine trouble and I bought it priced accordingly. After much difficulty finding affordable transportation I finally got it home and layed my eyes on it for the first time. I was really amazed at how massive it is in person but to my surprise it looked very well kept. I immediately sourced a couple batteries so I could fire it up and hear the engine. After several attempts to get the fuel system primed I succeeded and she roared to life. The engine had a minor but noticeable knock as well as severely contaminated engine oil (coolant in the engine oil) and hardly any coolant in the radiator. Somewhat discouraged I parked the truck out of the way until today. This morning I decided I had stared at it long enough and dragged it out of the field to work on it. I pulled the oil pan off and I was glad to see that it didn't have any metal shavings in the pan and no obviously overheated or damaged bearings. I haven't pulled any main caps or rods yet but at first glance the bottom end seems ok. I did notice it has 2 scored cylinders which I believe are the cause of my engine noise/knock. I then attempted to find the source of the coolant leaking into the crankcase by pressurizing the radiator but didn't have much luck. I applied about 12 psi of air pressure to the cooling system before the radiator sprung a leak from the upper tank and started to make creaking noises. I plan to plug the upper and lower radiator hoses to remove the radiator from the equation and apply 15-18 psi to the block and heads. I'm hoping the increased pressure will show the leak. From my research I found the most common issues that would cause this problem are the liners leaking from the lower O-rings or the oil cooler ruptured. Is it possible or likely that a blown headgasket could cause this issue? I'm my experience ruptured oil coolers usually put oil in the cooling system not the other way around as the oil pressure far exceeds coolant pressure. Does anyone have suggestions on how I could diagnose the source of my cross contamination issues? I would really like to diagnose this issue definitively before proceeding with the teardown and in-frame rebuild. I'm hoping one of the experts on here will be able to point me in the right direction.
Thanks!
Thanks!
