dherman304
- 53
- 18
- Texas, DFW
While installing my 2" body lift I could tell the nylon tube that connects the front to the back of the gas tank wasn't going to stretch and fit while still going the subframe. I cut the compression fitting off to pull through the subframe thinking that would give me enough slack to reconnect but it doesn't. Now I need to replace it... but do I? There must be a reason to connect the front of the gas tank to the rear but I dont know what it could be, sloshing???
The nylon tube connects to the front of the fuel tank with a brass elbow then connects to the tee towards the back of the fuel tank where small fuel filler overflow tube connects.
Unless anyone can give a good reason why this line exists Im capping both ends tomorrow.
