O/D T-case for the bobbers
wehring
26
Angleton, TX
FYI All,
The t-case in the M939 trucks has a .732:1 high range ratio instead of 1:1.
This is a difference of 15 mph at the same rpm.
Justin Wehring
979 997 3112
wehring
26
Angleton, TX
Yes but...
It is but you need to understand why. The low range reverse ratio is 11:1 and inexperienced drivers transition from drive to reverse in haste and shock the case. The cases I know of were also tied in with a heavy load. I have used reverse in low range with no problem.
The possibility of this happening in a bobbed deuce (much lighter and no tandem axles) is reduced.
Justin Wehring
979 997 3112
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
So a 939 Tcase is a direct replacement for a deuce Tcase? I am only asking cause I know nothing of the 939 trucks.
BFR
Rocket Surgeon
2,330
42
North Georgia
I see the point of sourcing a trans with a deeper O/D (or tom's gearset), but I can't see the advantage of this. I don't mind shifting the transfer to get a heavy load moving, but it would annoy me to have to do it all the time.
1,128
Isn't there a rotational issue here.............. like the driveshafts spin a different direction than the deuce... or am I thinking of the GMC 135/211 transfer/axle issue?
wehring
26
Angleton, TX
ideas
Excellent questions, all. I am stuck in AZ for another week before I can get home and make this more than an academic idea.
Justin Wehring
979 997 3112
