o m38a1 oil leak solved
rpso970
Boyce, LA
Ok fans had an oil leak on the m38a1 and couldn't figer it out. Check your Donaldson valve on the fording system. Had mine in the wrong position this is part of the fording system. valve was backwards and closed so it was blowing oil back into the crank case witch was the leak. Problem solved its the simple ****.
