O-ring kit for hydraulic control panel knobs?
Awesomeness
1,518
Orlando, FL
On my hydraulic control panel, the knob that selects cab/tire/suspension has started to leak hydraulic oil. The manuals have some exploded diagrams that show the knobs come out with a bunch of little o-rings on them. Are there kits to replace them all?
Awesomeness
1,518
Orlando, FL
Does the tm show part numbers for the individual o rings? If so they are usually spx parts.
What does SPX mean?
The exploded diagram is in the LMTV parts manual. In the maintenance manual all I have found so far is how to change out the entire assembly (but it might be in there somewhere).
scottmandu
36
Texas
I believe that panel and valves are made by Parker. They should use standard sized hydraulic orings and seals.
spankybear
910
WA
Oh boy! This sounds like another fun episode of "Guess That O-Ring"!
Working in industry, o-rings like seals and bearings are more or less standard for size. When it comes to o rings the biggest difference is what they are made our of. EPDM, Viton, Silicone, Buna-N, PTFE, FEP, Neoprene, Kalrez, ect...
If you have one in hand you can go to a place like McMaster Carr's website and go from there. With the width and ID you can get the dash number. You can also use something like this https://www.amazon.com/O-Ring-Sizing-Gauge-Plastic-Blue/dp/B012D6G13S
or this
https://www.youtube.com/watch?v=98Kb26RVCzg
