Oa331 compression test
mthullm54a2
tonasket wa
I am going through my 51 REO with a gas engine and gave it a compression test all cylinders are around 90 psi it seams kind of low but I don't know much about these engines it dose not burn oil but when we first started it up it was sitting for a couple years and had water in the oil and I was getting some bubbling out of the radiator after an oil change and water just to drive it home now oil in water but brought a gasket set to replace the head gasket just to be safe but my question is is that an ok compression for the engine 90 psi
texas30cal
87
Brenham Tx.
I'm not familiar with that particular engine, but the rule of thumb for gas engines is 90 psi minimum to run, it may be hard to start (esp a 2 stroke) and probably won't run very well .
NDT
6,391
Camp Wood/LC, TX
That engine has wet sleeves, meaning there are O-rings between the cylinder and block. The water can be coming from there as well.
Mackafd
Walnutport pa
I have a few military reo 331 engines and a few of the civil. ones and the books all say 140 psi. but every one of my engines that are in running truck are all around 80-100
