OA331 crank journal question
Tilyn52
Minneapolis
Hope I'm in the right forum. Trying to find the crank journal diameter spec. They mic at 2.155. Bearing have no markings so trying to find if it is standard or undersized .
m1010plowboy
2,712
Edmonton, Canada
Usually I'd say you'd need to lay-out some more information but I searched 0A331 and found a REO engine. Is that right? https://commons.wikimedia.org/wiki/File:REO_OA331_engine.jpg
In the source line I found a link to the TM number. https://www.scribd.com/document/166312718/TM-9-819-M34-M35-AND-M36-1952-with-change-I-and-II
Searched TM 9-819 and got a couple of links http://olive-drab.com/od_mvg_www_deuce_m35.php .....and found a manual online for around $36.00 http://themanualguys.com/7 ~ Trucks...2.5 Ton Cargo Truck ~ Maint Manual ~ 1952.htm
Found a blurb in OD that said """"'Manuals from the new system will be numbered TM 9-2320-209-xx ...""""" Went to Jatonka's site and found these. http://www.jatonkam35s.com/DeuceTechnicalManuals/TM9-2320-209-20-2-1.PDF
....http://www.jatonkam35s.com/jatonkaM35sTMdownloadpage.htm
I'm not sure which page it's on but I'm thinking if you thumb through the index you should be able to dig up the engine spec page. Hope that helps!
Kaiser67M715
26
NH
starting on page 102, Repair and Rebuild Standards, Manual TM9-2805-22-35-Field and Depot Maintenence manual for Engine(Reo Model OA-331)
Diameter of main journals= 2.5075-2.5082
Connecting rod journals= 2.1805-2.1812
I would say you measured connecting rod journals, and that they are .030 undersize.
