Odd turning up the fuel question
rickdavis81
84
Rich Hill, MO
I have a m35a2 with an lds and I/p that didn’t come with a fdc. I went to adjust the fuel screw today and realized it is just a plug, so it appears, instead of a screw with lock nuts. Can I adjust it or what do I need to do? I changed the hydraulic head o rings awhile back because I was gaining oil. Ever since I haven’t built as much boost, started having hard hot restarts and now I’m having hard cold starts. Thought maybe the fuel screw backed off.
cattlerepairman
3,154
NORTH (Canada)
@rickdavis81 just mentioning that one wants an LDS that is a thick deck (TD lettering cast into the block near the data plate) as a candidate to really turn up the power.
The older regular blocks may not like the increased pressures and blow the head gasket or warp.
Also, a gauge for exhaust temperature is really a should-have so that the driver sees the temperatures the turbo is exposed to.
Guidance varies but EGT should stay under 1300 F.
rickdavis81
84
Rich Hill, MO
thanks for the heads up. I installed a pyro and boost gauge already. I’ll check for the block stamping when I get a chance
