Official DENTON, NC Buy Sell Trade Thread 2023
Blake
61
Opp, Alabama
I sold my CUCV and have the following used takeoff parts (unless otherwise noted) avail. I go to the rally for the good time and wont bring unless there are prior commitments. PM for questions or addition info.
m1008 fuel tank complete - $75
m1008 brake booster/ master cylinder - $75
CUCV radiator / came out of a parts truck - $150
CUCV injection pump core $100
CUCV steering box - $50
CUCV power steering pump with bracket and hoses - $250
m1009 rear drive shaft - $100
m1009 front drive shaft - $100
m1008 rear driveshaft - $250
m1008 front driveshaft - $100 - Matt444
New AC delco 6.2 water pump - $75
New purolator, fram, and casite engine oil filters - $3 each
New m1008 front brake hoses (to calipers) -$10 pair
CUCV air filter housing - $25
Complete 6.2L engine/unknown condition with no accessories - can take large or small parts off as needed
CUCV NP208 Transfer case - $150
CUCV TH400/torque converter / unknown condition (taken out of a parts truck) - $250
CUCV torque converter - $50
CUCV stock fuel filter housing - $50
M1008 rim/tire - $50
M1009 rim/ tire - $125
CUCV 24v gear reduction starter - $75
CUCV fan/clutch - $25
CUCV intake manifold $25
CUCV engine wiring harness - $250
CUCV dash wiring harness - $300
CUCV steering column - $75
Miscellaneous CUCV engine parts - PM direct for parts request
Miscellaneous:
PRC25 and am2060 amplifier/power supply - $500
Large "wrecker" snatch block with loop/swivel on end - 3/4" cable - $200
M116a2 with MEP-003a 10KW diesel generator with fresh/new crate engine (must pickup in southeast virginia/ wont deliver to rally) - $2900
NOS Autolite "2245" military spark plugs for jeeps/trucks. Packaged under AR7S, 1966 date, made in USA- $30 each
Temper frame tent - 2 sections with ends. Total 16' long by 20' wide. Vinyl sides (tan) with vinyl ends (green), rain fly, raised stanchions, and floor. Extra vinyl tan sides. Stored inside. Frames in carrying bags. $800 for all
M35a2 outer windshield frame (no inners) - $75
M35a2 soft top bow/side pieces - $100
M16 military metal rifle rack - $75
Oxyacetylene
179
Stoneville, NC
Still have this snatch block for sale or trade. $50 or trade me for ? Gallon jug for scale only. I believe it is rated for 5/8 cable.
Want to buy:
  • AB-621 "rocket launcher" style portable mast, or something equivalent.
  • Front roll bar that mounts to the rack on an MV850
matt444
74
Edgemoor SC
Put me down for the M1008 front driveshaft
Sent from my SM-S906U using Tapatalk
Oxyacetylene
179
Stoneville, NC
I also need a trailer hand brake lever assembly, maybe a set of 11r20's in good, roadworthy condition, and a set of the Isuzu truck wheels that fit the Deuce lug pattern. The tires do not have to be NDT's, I am looking at options. I recently acquired a M563 trailer that I am working on cleaning up to put on the road for hauling my ATV or UTV behind my truck. I might also be interested in some sort of tie down rings that I could add along the sides of the trailer. I could get the weld/bolt on rings from HF, but maybe someone has something that fits the theme better.
wheelspinner
1,521
North Carolina - FINALLY !
I only plan to bring this if it’s spoken for.
1,808
Hey gang, I'll be there Saturday only. I have 4 M1009 rims and tires. Rims are fine, tires are fair. $500 for the set. I also have a "display" radio system in my M1009 that needs to go. It consists of the radio rack with bases for the RT524 and 2 R442 bases. Has an RT524 and one R442. Has the loudspeakers and handsets as pictured. Also has antennas w whips, mounts and brush guards. I think they are AS3900 bases. I need $500 for this. I was told "display only" . That's how they will sell, I'm not going to open them up to see what's there. I'll not bring any of this stuff unless there is a commitment and a small deposit. Sorry, knee surgery Thursday, can't bring it just to show.
RJTM998
373
North Carolina
PM Sent
CGarbee
552
Raleigh, NC
I also need a trailer hand brake lever assembly, maybe a set of 11r20's in good, roadworthy condition...
I won't have them at the rally (too much going on between now and then to get them....
I have some decent Goodyear and Michelin 11r20 at the house. I also have a set four hours away in storage that are very nice...
Talk to me over coffee at the MKT if you haven't found another source...
TaylorTradingCo
68
Ringgold, GA
I have so much stuff, where to begin:
Mutt parts - pretty much anything that can be pulled off of one
M35A2 parts - again, anything that can be pulled off
M800 series parts - tranny, transfer, steering components, most cab related pieces
20' slave cable
medium adjustable towbars
brand new in box Solargizers
M37/early M101 wheels and one WWII combat rim
pedestal
50cal cradle
four point quick release helicopter seat belts
lots of old radio stuff from 40's-70's
WWII foot locker
generic vehicle parts - tail lights, blinkers, blackout lights, dash gauges, 24v light bulbs, jerry can mounts, pioneer tool kits
I don't get on here often, so feel free to text me with your needs.
Derek Taylor
423-255-6509
wheelspinner
1,521
I can bring these if pre-arranged
1,808
Radios are spoken for. M1009 rims still available.
