Jillmd
- 7
- 3
- Wasilla, Ak
HI,
I built a moose hunting buggy up here in Alaska. It has 2 front steer 2.5 ton Rockwell axles (four wheel steer). I recently removed the stock hubs and bolted up 611 Meritor gear reduction hubs to the 2.5 axles. In this configuration, I do not or could not us the CTIS. Is there any reason why I could not remove the CTIS seals, plug the air port holes, and make the entire hub oil bath? I have new inner seals, to me they should be able to hold oil in if they keep water out. Thank you in advance for your help and sorry if this is the wrong forum for this question.![281886677_5105255226187965_1727186576052511795_n.jpg 281886677_5105255226187965_1727186576052511795_n.jpg](https://www.steelsoldiers.com/data/attachments/633/633110-49878a2201835304acb7a01a2783033d.jpg)
