Oil Capacity Issues
Chris518
Albany, NY
I have read in quite a few places that that an M35a2 trans takes 5 qts and the tranny takes 7 qts after a full drain. Yesterday I put 4 qts in the trans and it started overflowing out of the fill hole. I got frustrated and moved to the transfer case and put 4 qts in. Stuck my finger in and the oil level is right at the fill hole (too much).
Do I have my capacities wrong??
Is it best to pull the drain plug and just drain a little bit of fluid off to get the right level?
For reference, when I drained the fluids, i had the plug out overnight so it would drain everything. I am also pretty sure I did not pull anywhere near 5 qts and 7 qts out when draining.
Thanks in advance! You guys are always such a huge help!
m715mike
3,923
Montgomery, Texas
Check out Lubrication Order LO 9-2320-209-12-1
You can download a copy from the TM section on this site.
Transmission with PTO is 8.5 pts. (i.e., not qts)
Transfer case is 7 qts.
I bet 4 quarts in a transmission w/o PTO would make it over flow.
Chris518
Albany, NY
Shoot! I had printed out that page of the LO and it definitely looked like a "q" rather than a "p". Thanks for the clarification. With that said, is there a reason they dont have a quantity listed for a transmission w/o a PTO?
m715mike
3,923
Montgomery, Texas
That’s a good question. My truck has a winch and the PTO, so I’ve never given it any thought.
I’m sure someone else will chime in.
frank8003
4,989
Ft. Lauderdale, Florida
Once drained thru bottom plugs that you put a new squish gasket onto and tightened then fill whatever it is thru the tell tale hole while vehicle is level. Too much and extra will come out and not enough and it won't rise far enough to come out. Just overfill it a smidge and let it sit a bit then plug it and you done.
It is a splash system, no pressure. Assure vent is clear to work.
Chris518
Albany, NY
Ahhh, the rule of thumb answer I was just looking for. Thanks a bunch!
