Oil change Tips
pwrwagonfire
Central Massachusetts
Im looking for any tips/words of advice that can be offered for changing the oil in a 64 WM300
Have heard a few...but Im going to do it myself for the first time this week (or next) (hopefully!) and would like to hear as much about it as I can
FYI: The filters it takes is not the "bunch of socks in a nylon bag" like my buddys '56, but it is a metal cartridge filter instead
davesgmc
131
Mclouth, KS
#1 tip, use a drain pan that has a capacity LARGER than the engines oil capacity! My 5 ton with a 6-71, I had NO idea how much oil it held, that is until the 5 gallon bucket got full and dumped the additional 4 gallons all over the shop floor......they just don't make enough oil dry for something like that, i know!
NDT
6,343
Camp Wood/LC, TX
Use your empty oil drain pan up on top of the engine next to the oil filter canister to accept the old filter. Use a old soup can to catch the oil from the filter housing drain plug. Then use lots of paper towels to clean the bottom of the canister, it will be full of sludge.
pwrwagonfire
Ive heard to save the old washer from the filter(?) or else it will leak like crazy....:?:
