oil cooler line nut - help
jag7720
Kansas City, MO
While removing the old radiator I could not detach the oil cooler lines from the radiator. So I detached them from the flexible part of the line... I was able to remove the lines but the nut on the line will not turn so I had to rotate the whole line.
I have soaked them in PB Blaster and heated them... let them cool and repeat but they will not budge.
I tried putting the line in the new radiator but the threads don't stop at the same point.
:?: Anyone got any ideas how I can free the line nut from the aluminum line? :?:
1,176
Are you using a flare nut wrench or box-end wrench? I recently installed a new radiator in my cucv, I had no trouble though. Those lines just have a flange ring and an O-ring to seal them. Sounds like corrosion/electrolysis is your issue.
Wolf.Dose
9
Boehl-Iggelheim, Germany
Forget it, corrosion on the aluminium lines. Look for new parts or get them coustom made made at your local hydraulic shop. The connection is a GM special design and not as general hydraulic spare on the market.
Wolf
