oil cooler lines 6.5 turbo
FMJ
37
Las Cruces, NM
I need to know how to connect the cooler lines to my Teds 6.5l engine. The space is to cramped for one to fit without bending it to much. Will a 6.2l oil filter adapter/block fix this?
I have a 1997 6.5 in my 86 1028A3, the only thing I had to do was install bushings and screw in the 6.2 oil cooler line fittings into the bushings in the block. It all bolted right up.
FMJ
37
Las Cruces, NM
There is no difference in the basic engine block.
Except the 6.2 and the 6.5 have different size block fittings.
FMJ
37
Las Cruces, NM
If the 6.5 has an extended oil filter adapter, ditch it, and use the the info I provided.
Assuming this is going into a CUCV
FMJ
37
Las Cruces, NM
the 6.5 and the 6.2 are exactly the same externally, the 6.5 you have may have a bolt on oil filter/cooler adapter
If this is going in a CUCV, unbolt it, and use the info I provided.
