toocool
- 0
- 0
- plyesville md
does any one know if you can block off the oil cooling lines on the 6.2 diesel motor?
I have had my 1008 for 2 years. The engine oil cooler ports were capped off at the filter base and radiator when I purchased it. I have towed to full gross in the Winter, and the Summers exceed 100F here rolling the 37" Hummer Radials. It has never ran hot, lost power, or seen a temp. light.does any one know if you can block off the oil cooling lines on the 6.2 diesel motor?
