Oil Filter confusion
Westex
El Paso, TX
O.K.--I've read the posts I could find on oil filters. Trying to change the oil now on my M35A2. There are 2 oil filters. Do they BOTH use the NAPA #1133, or are they different filters, a primary and finer secondary?
emr
25
landing , new jersey
When u do the fuel filters there are the 2 on the side of the motor and the primary is under the right fender area, U are supposed to be letting that one drain now and again to see if there is any water in there, and U may find the pet cock is cloged/rusted up and needs to come off to make it work, that is common, that filter is a shorty, the other 2 are the same,all the diameters are the same though. u will find when U buy those they may have a different diameter hole in the center from the ones in the truck , do not worry they work just fine, the Military uses both sizes all the time...when they go on they center right up, just an FYI, for the next job...:-D
