Elwenil
- 40
- 0
- Covington, VA
EDIT: Er, sorry for the hijack, I didn't originally intend this post to be this long, lol...
I personally don't like most of the oil filter style magnets because they fit over the end of the filter. I can't tell what the one in you link looks like because I'm at work and all the images are blocked, lol. Anyway in the end of most oil filters are the backflow and pressure relief valves. For those who don't know, the first is designed to hold oil in the upper parts of the engine after shutoff so that the valvetrain doesn't have to wait for the oil system to pressurize for it to get oil up there. The second valve is made to let oil bypass the filter element in the event it becomes clogged for some reason. The thinking is that dirty oil is better than no oil at all, and I have to sort of agree.
The issue with the filter magnet is that it collects and holds all this junk in the end of the filter where most of the working parts are for these valves. Most are just flapper valves or a spring loaded element that allows the pressure to build and compress the spring allowing oil to go around the end of the element. If all of this crap is collected in the end of the filter housing, I doubt it will work if needed.
A better idea to me, would be a strong magnet attached to the outside of the oil pan, away from the pickup. This would collect the metal bits and keep them out of suspension in the oil and hold it away from everything. Naturally the only way to clean it out would be to drop the pan, but it should be anything you would have to do very often. I don't like the oil pan plug ones anymore, either. Ever since I had to take a piece of wire and poke out a clog at the drain from all the garbage collecting on the plug to get the oil to drain out smoothly.
Anyway, that's my two cents on dirty oil and magnets.
A few issues with oil filter magnets. One major issue is that probably over half the garbage floating around in your oil is non-metallic, or is babbit, copper, or aluminum bearing material, and therefore won't stick to a magnet. Not that magnets don't collect a lot of garbage as anyone who has torn down an automatic trans with one in it can attest.Polverone said:Well, there went this idea:Elwenil said:As far as the rust and magnet bit, 100% rust shouldn't stick to a magnet.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91403
