Hummer Guy
- 805
- 93
- United States Louisiana
I've been having a small oil leak around the oil filters for the pass several months or so, it only leaks when the truck warm up. I thought it was the gasket under the oil filter housing, so I changed them and torqued it down, it wasn't, it still has the same leak after about 20-30 minutes of the truck warming up. I heard of people saying the FDC leaks but the leak I have is oil, not fuel at all.
Have you guys had a oil leak around this area? If so, where was it, the common place I hear is the gasket under the spin on filter which I checked and the FDC.
(I have the spin on oil filter)
