oil leak at Injection pump to block
crzyxj
Lander, WY
How the heck do you change the line from the block to the Injection pump? I am having **** getting the old line off. Someone has installed a pushlock fitting on the block and the inj pump end is a flare nut. Any ideas that do not require pulling the pump?
cattlerepairman
3,530
NORTH (Canada)
It is tight and the steering box is in the way. Can you remove the injection pump end of the hose and then get an exacto knife up there to slice the hose off the pushLok fitting? You can't install the new hose that way, but it would give you more room to get a crow's foot wrench or similar up there.
https://www.steelsoldiers.com/showthread.php?113320-Busted-oil-line-at-the-injection-pump
some pictures in this thread: https://www.steelsoldiers.com/showthread.php?169340-Injection-pump-oil-hose
https://www.steelsoldiers.com/showthread.php?178291-Oil-Leak
