Oil leak, Loose Bolts
Deplorable1
56
East of Cincinnati
Hello everyone, I have a question some of you may be able to help me with.
Today I was looking over the Deuce (after driving it yesterday) and noticed a slight amount of oil around the front exhaust manifold bolt. So I grabbed a wrench and sure enough it was about 1/2 to 3/4 of a turn loose, so was the bottom one and as I moved rearward they were slightly less loose.
I plan on degreasing the motor and driving it around to check for any leaks.
So my questions are:
Is the head OK?
Is this normal for the manifold bolts to loosen up over time from vibration?
Does this mean I need to replace the exhaust manifold gasket?
Is there any tips or info on what to do/look for?
I'm sure the wealth of knowledge on this board/site will keep me from aua
Thanks for any input!
Here's some pics: Arrow points to the bolt in the second pic.
rustystud
2,725
Woodinville, Washington
Is the head OK?
I'll be honest with you. It is almost impossible to eliminate all oil leaks on this engine. It's like a "Detroit Diesel" ! Well not that bad, but it leaks. So don't sweat the small ones. It's the "large" leaks you need to be concerned about ! Mine still "seeps" along the block, after dealing with it for years now. As long as it is not "dripping" on me when I'm under it, it is OK to use.
Yes the bolts will come loose due to vibration, so you do need to regularly check the engine. Also good "lockwashers" helps, along with some "Loctite" on the troublesome bolts.
cattlerepairman
3,183
NORTH (Canada)
The "bolt" you are pointing to is one of the studs and nuts for the exhaust manifold. It is oily likely because oil from higher up is dripping on it. Likely from the valve cover gasket or from the head gasket. My rebuilt LDS also seeps here and there and I used a lot of care with seals and sealing surfaces.
The oil you are concerned about may represent years of accumulation. Just clean it off and see how long it takes to get dirty again.
pjwest03
36
Vestal/NY
With a lot of older vehicles of many types, they fall into the category of "If there's no oil under it, there's no oil in it." As rusty said, if it's not leaking out in buckets, it will be fine.
Deplorable1
56
East of Cincinnati
Thanks for the input guys, I just wanted to confirm my suspicions and not overlook a potential disaster. On to the next project.
Sent from my moto e5 supra using Tapatalk
