Maybe a head gasket? Get a flashlight warm up the engine and check all around the heads. If they are seeping you will be able to see it. It could be leaking at the rear of the head or on top.I am unable to crawl around my truck for a few more weeks, but I think I have some oil drips coming from the passenger side of the engine. I think the leak is higher up, near the firewall and engine head area. Any guesses?
I hope you mean valve cover gasket. Many things to leak up top. Vacuum pump, sending unit, valve covers. But yes, oil leaks are hard to find. Not always. I would pull the engine and change all the gaskets if it were bad enough.Maybe a head gasket? Get a flashlight warm up the engine and check all around the heads. If they are seeping you will be able to see it. It could be leaking at the rear of the head or on top.
