oil leak
choll
Las Vegas,NV
Just replaced my oil cooler line on the oil filter they had a leak. Well I knew things went to well, I replaced them in about an hour. After the truck warmed up and the oil started moving I noticed a leak above the lines close to the exhaust. Its very tight so I could not trace the leak all the way back. Anyone have this issue or have an idea what would be leaking
Florida9
Lantana, FL
it could be the oil dummy light it screws in at the top back of the block on the driver side if some how it came loose you would see a good amount of oil leaking or maybe a rear main seal
