cjkeeliii
- 3
- 0
- Thomasville, GA
The TM says that if my CUCV is a late 1985 model that the oil pan will not have a lip and that RTV should be used. Mine is late '85 and has a completely flat lip. O'Reilly's 6.2 diesel oil pan gasket set has a gasket that fits across the entire width of the oil pan lip, hence the newer style oil pan. In other words, it's not the early gasket that the TM shows which appears to only fit across a portion of the oil pan lip. So, should I use this gasket, or RTV? Thanks.
