oil pan removel
jay741
RI
hi i have an m1008 and the oil pan just wont come out it seems like somthing on the inside is preventing it from. i have all the nuts out and the dip stick out. i can move it around but it just wont come down. i have a 6.2 in the garage from a humvee and that pan came out no problem. i was just wondering if there are any tricks or tips thanks
beanman1
in the south
the oil pump pickup tube is preventing it from coming out i dont recall what size the bolts are but you are going to have to lean it and get your hand/tool in there to take the pick up tube off and then it should come out
kassim503
Stony Brook, NY
I noticed a clearance issue between the oil pan and the front crossmember, it would not let the pan drop low enough to clear the front main bearing cap. My fix was lifting the motor half an inch by placing a jack and block of wood under the crank pulley
