Oil Pan Skid Plate
Kenny714
-1
Forked River,NJ
Real simple and easy protection. I got the steel FREE from work. Scored the bends with a cut off wheel and bent it up in the vise. Ran a thick bead of weld over the scores after I got it bent up. The notch cut in the rear is so I can change my oil without removing the skid plate. It's all bolt on with factory hardware...Bonus!
ALFA2
Phoenix, Arizona
That is good thinking Kenny, looks like OEM style part when painted, and additional protection for the pan is always good.
Thank you for posting.
ALFA2
Kenny714
-1
Forked River,NJ
Thanks! Only improvement I may do is weld in small gussets on the bends to strengthen it up a bit. Probably not necessary but, It'll keep me busy for an hour or so.:mrgreen:
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I guess if your looking for something to do. I doubt that would do much of anything other than to keep bugs off the front of the pan.
Speedwoble
300
New Holland, PA
I had a diamond tread skid plate on my 4-wheeler, I got stuck on many object, in part because it wouldn't "skid"
That said, it does have a very practical purpose. On my 69, I had a tall piece of firewood get wedged between the ground and that frame crossmember. The fuel line was run along the bottom edge of the crossmember, as on yours, and the fuel line was crimped nearly in shut. Therefore I say it is better protection for the fuel line than the oil pan.
Kenny714
-1
Forked River,NJ
I'll be adding gussets to the corners but, the truck won't be seeing any hard hits. It's primarily used to pull our mud trucks out of the holes and trail riding. It may see some sand hills and some small trees/brush while manuvering to yank someone out so I think it will accomplish what I need it to do.
Thanx for the feedback!:)
