oil pressure after turbo
6wdcummins83
Hudson valley NY
Just got my turbo on and everything is running now, to those who have put a turbo on a nhc 250 what oil pressure should i be having at idle and while driving? cold i had about 60 and driving it came up to about 80 psi. is that high? no fuel mods yet and pictures are coming but its dark now i just took it for the test drive (about a mile down the road)
406anthonyj
Montana
I turboed mine. Didn't change the oil pressure at all. Mine is about 90 cold and about 65-75 warm. But it Montana our colds Are 10 to -0. If the turbo changed your oil pressure a lot check your oil lines to turbo.
WillWagner
2,756
Monrovia, Ca.
That is normal pressure. Adding a turbo doesn't change oil pressure. You plumbed the turbo supply from the FILTERED side, correct?
wcuhillbilly
Devils Tower, WY
Turbo,,,,,, Im sure it woke the ole girl up some.... Dont mind the oil pressure,,, its fine. Cummins tend to run a higher pressure than most, and way higher than civy cars/pickups.
