- 9,576
- 211
- 63
- Dickson,TN
The oil pressure gauge hasn't worked right on my m35a2 since I got it. When I start it the gauge will come up about a needle width off of zero and never get any higher or lower. It had the 60psi gauge in it when I got it so I thought maybe someone had instaled a 60 psi gauge to a 120psi sending unit. A friend of mine had some extra gauges so I got another 60psi gauge and a 120psi (both used). I put in the 120psi gauge and it would register about 100psi at idle. That seems way to high to me. I then installed the other 60psi gauge and it wouldn't even move. Could I have a sending unit problem? I have another sending unit I could try. Is there a way to tell the difference between a 60psi and a 120psi sending unit? I just want to make sure my oil pressure is ok so I don't burn my engine up.
