Oil Pressure Gauge
Tinwoodsman
76
Comfort, Texas
I need to replace my oil pressure gauge. Does it make any sense to go with the 0 to 120 psi versus the 0 to 60? I also have to get the sender.
BFR
Rocket Surgeon
2,330
42
North Georgia
IMO it doesn't really matter, but my only use for that gauge is to monitor for below normal pressure(which both show) as opposed to above normal pressure(which only the 120 psi set) can show.
steelandcanvas
86
Southwestern Idaho
With the 0-120 you won't get the needle sweep as you would in the 0-60, therefore not as accurate. Ok to go that route if you have 60+ pounds of oil pressure, but for a stock Deuce the 0-60 is adequate.
