oil pressure port
hkyplr18
Oklahoma
I'm looking at an M35A2 that is for sale. The oil pressure gauge on the panel is showing low op at idle and high rpm. Can someone tell me what thread the op port is on the engine case? 1/4 npt? I need to put an external gauge on it to see what the actual direct reading is.
Thanks in advance.
welldigger
15
Benton LA
I can't remember what the port size is but check the engine oil. If it's high then chances are fuel has thinned the oil out causing the low oil pressure.
Not necessarily the worst case scenario. It's usually easy to fix. But definitely change the oil before running it hard if that turns out to be the case.
It could also simply be a bad guage or sending unit.
cattlerepairman
3,183
NORTH (Canada)
It is 1/4 IPS/NPT threads at the block. Passenger side rear of the block; you may have to remove the air filter bucket, it is tight there.
Common problem is a mis-matched gauge and sender unit. There are 60 and 120 psi gauges and sender units and they show wonky pressures when interchanged. Some soldiers A apparently did not care. Sending unit can be blown out with compressed air.
hkyplr18
Oklahoma
Thanks so much! That is exactly what I was looking for. I am familiar with the mis-matched issue and that's what I'm hoping/guessing the problem is. Should have confirmation tonight.
Thanks Again
dmetalmiki
2,027
London England
Guessing you allready checked the oil, so as you are thinking, definately try a "what you see is what you have" gauge, And replace the the faulty unit/s. good luck in the (easy hopefully) fix.
