Oil pressure
mill1970
worcestershire uk england
Hello, can anyone tell me the engine oil pressure for the m35 multi fuel first when started, and then when engine has been running for some time. Many thanks, also where is the cheapest place to get a some fuel and oil filters from?
Kaptin kalen
northridge, CA
Hi, Mind starts at around 60 cold and drops to 30 when hot at idle. Napa has all the filters at around 12 dollars each. Make sure you change the primary filter on the frame. It comes in two sizes short or long. The housing size will let you know the one you need. K
nosliw
Rural Ky
mine is about the same. 60 at startup and 30 warm.
i always heard a general rule of thumb was 10 psi for every 1000 RPMS.....but i dunno.
