oil psi gauge
chevy79k5
libertyville il
hey all id like to put a oil psi gauge in my m1009. i like to see numbers not lights for thoes things. but anyway where should i go about mounting it under the hood, im kinda of new to these truck so any help would be grate thanks Ryan
Massm35a2
New Bedford, MA
I added one to mine, I removed the idiot light sensor and attached the gauge stuff there. It is at the back of the engine behind the intake manifold.
kapnklug
spencer,ny
You can add a 1/8"NPT branch-T at the location of the idiot-light sending unit (driver's rear of engine block), then screw both senders into the T. Be sure to get an electrical (not mechanical) gauge, since I've had the tube break on a mech. one and sprayed oil all inside the dash! JC Whitney has them for about $45 for gauge and sender.
