Doug D.
- 27
- 18
- Winterville Ga
how hard is it to replace oil pump in humvee?
not sure I will just trying to get info. I have some knocking going on and oil pressure gauge in the 10-15 psi when warm. I will be testing the oil pressure at the sender. it runs good going down the road though.The first question is, why do you think you need an oil pump? They don't wear out.
10-15at idle? Is completely normal…not sure I will just trying to get info. I have some knocking going on and oil pressure gauge in the 10-15 psi when warm. I will be testing the oil pressure at the sender. it runs good going down the road though.
Yea ours is the same way, makes me nervous when any engine I’m behind isn’t showing 30 psi or better at idle. But some are just fine for many miles like that.how hard is it to replace oil pump in humvee?
