- 424
- 60
- 28
As a brand new owner of the M817, I've noticed the oil pressure at 60PSI at Idle and 90 at about 1500 RPM on the Cummings NHC-250.
The oil guage reads 0-120. Is it possible the wrong sending unit was installed (0-60) vs. the 0-120....? Is there another problem that would cause the idle psi (after warmed up for 30 mins) to run at 60psi and 90 at speed?
Thank you
Bob
p.s. The picture is with the engine just started....showing close to 90psi at idle......??
Thank you
Bob
