ok guys i need some battery help with a m1008
$!N!$T3R
mountian home Ar.
I got a m1008 about one year ago,love the truck,but had something very weird happen, it has the stock battery's but the one by firewall exploded like some one shot a 45 under the hood. as soon as the key turned (boom!!) has ran fine for one year and is a great truck...so...what now? just the battery you think or am i looking at some big problems? maybe go 12 volt...guys any help? as i am lost on this one:cry:
rickf
1,513
Pemberton, N.J.
And very liberally dust the engine compartment with baking soda to neutralize the acid. Do thin until it stops foaming otherwise you will find out just how fast a Chevy can rust!
Rick
$!N!$T3R
mountian home Ar.
thank you so much. I was hoping that's all it was.getting the baking soda out right now . you guys have always been great help, i'll lett you guys know if i find something other than that. but that's what i think happened too. thank you again:beer:
1,174
When you put a new battery in, check it with a volt meter. Measure it on it's own terminals. Then start the truck and measure it again, on it's own terminals.
It should be slightly higher when it is running. If it is way too high, shut it off , you could have an alternator voltage regulator issue. If the voltage looks good(15 or less) you should be all set and you can assume it was just a bad battery.
rnd-motorsports
Evart,Michigan
:ditto::ditto: clean the battery asid stuff is nasty will couse its own problems and as stated check alts . I think if you have not done the doghead starter fix would be a good time as this might have caused a volt spike or such and that starter relay will not take much. just check things and watch what will and willnot work. way not have any more problems but you never know! GOOD LUCK!!2cents
WARWAG
You might want to invest in a set of battery warmers as well if your temps get down below 32 degrees all winter. If a battery freezes all kinds of bad things can happen. Oh and as stated above I would wash down your engine compartment asap with baking soda. You could dump a whole box of arm and hammer in a partially filled Hudson sprayer (warm water) and shake until everything is mixed up. Then spray down the entire engine compartment. Wait a bit and then wash again with water or a very low power pressure washer. Good luck.
$!N!$T3R
mountian home Ar.
thank you guys so much, so far it was just the battery. i checked it with my meter and it was under 15 with it running, and 30 all together even with the rpm up so i think its cool now. oh the gauge on the dash is in the green but its very close to the red,but all looks OK so far.
