bubba_got_you
- 6
- 0
- st,petersburg Florida
Ok so my m37 318 is running bad it will run fine then it will chug until its ded. I the problem only happens at idle
There is no unusual noise so I figure it’s a fuel problem because it will run fine then no go. It will restart after I pump the gas and crank for 30 sec.
[FONT="]So I replaced the fuel filter thinking maybe it’s clogged…nope…. but I did replace with a glass filter so now I can see what’s happening. So when its at idle the fuel filter will run almost dry with the pump only spattering a little bit of fuel in and the filter is practically empty. Im thinking a bad fuel pump? Because it only happens at idle and will run ok with the idle way up. Maybe a hole in a diaphragm? [/FONT]
