Ok, What the hell?
1,163
RE: Problem?
Ouch.....bearing seized up.............
6x6pinz
Mesa, Az
RE: Problem?
In this case I guess pictures are not worth a thousand words. Does not look like the surfaces the bearings ride on were damaged.
Barrman
2,190
Giddings, Texas
RE: Problem?
I agree. The spindle surface between the bearings is not machined smooth when built. My M715 spindles are the same. They are so rough you can't run a rag over it without a hand full of lent being left on the rough spindle surface.
Or am I missing something in the pictures?
zak
-4
Ortonville, Mi
Make sure the surface the seal rides on is smooth and grooveless. I don't know if redi-sleeve makes one to fit here but somebody should know.
Larry Sage
