Old Generator Identification
Empty Pockets
Plymouth Meeting/PA
I need some help identifying an old generator. I think it is an old military unit, but not sure. I know it is a 15kw three phase generator with a diesel engine. I would like to know a possible model number, and manufacturer of this unit. Onan maybe? What engine is in it? Possibly a range of years? It appears to be older than any of the generators being auctioned off at GL. Does anyone know what gauge is missing? Can anyone recommend a parts source for this unit? Finally any opinions on what this unit might be worth? I'm told it will start even though it has been sitting for a few years but we all know how that works out. Any help will be greatly appreciated.
jbk
livingston la.
looks like mb series 60s vintage the motor is hercules dd198 earleir version of this engine design that stayed with the mep-004. motor parts shoudnt be hard to find, but everything else will be tough. theirs kind of a following over at smokestack for these. delks may have parts. dont know about worth maybe several hundred. i paid 700 for a 004 that cleaned up and worked.
Isaac-1
50
SW, Louisiana
I agree, looks like one of the MB's to me, one of the regulars over on the SmokStak generator board worked on these in his earlier days in the Air Force. I have read the control systems on these are a real nightmare, way more complicated than they needed to be and were designed by the Air Force to use what was to them standard aircraft control parts, so insanely expensive and hard to get for anyone else. For the range of years the MB's were mid 1960's through late 1970's, you could narrow it down based on exact model and revision, I just have never looked at them that closely, almost considered buying one the local Forest Service had up for auction, but passed on it mostly because of the known control system issues.
Ike
Empty Pockets
Plymouth Meeting/PA
I after doing some research I think it might be a MB-19. Were these used exclusively by the Air Force or did anyone else have access to them? Does anyone no what manuals this thing takes?
Where can engine parts be found for it? Already I have learned more in one day than the owner who has had this for years.
NDT
6,476
Camp Wood/LC, TX
Google the NSN painted on the side 6115-00-606-9693 for lots of info and parts sources.
Empty Pockets
Plymouth Meeting/PA
When I first saw the generator it reminded me of some of the WW2 gas generators with the jeep flat head 4 engine in them. Then I opened the access panel and saw the wiring schematic that says diesel then I realized this beast was different animal.
reddmpayne
redding, CA
Empty Pockets. Here's hoping you are still out there. I just bought an old MB19 nsn6115-00-689-4486 and it doesn't look like the one pictured. I am also looking for wiring information, did you have any luck? The TO attached to this gen set is 35C2-3-343. reddempayne
