Old long Deuce Airpack and long 5-ton airpack
Robo McDuff
In memorial Ron - 73M819
1,611
Czech Republic
I have been told the old long deuce air pack and the 5-ton air pack on the M39 are interchangeable, or better, you supposedly can use the long deuce air pack on the 5-ton.
From the 2014 GA Rally, I brought home a Deuce air pack, since I have problems with my brake system, including loosing dot 5 fluid during prolonged standing without visible leaks.
Left the 5-ton, 2x right the long Deuce AP Looking at the two next to each other (more or less), they are definitely different, and the 5-ton is bigger. Does the 5-ton version provide more fluid/power to the brakes?
If the Deuce provides less, I certainly will not change them. Also, I am thinking of opening both and check; I have to redo the current system and I do not really trust an air pack laying around in a damp area for three years.
If both are ok, I was thinking to use them together as two APs in a dual brake circuit. That is enough planning and puzzling already, two unequal air-packs might complicate things and not be a good idea.
Rmtaunton
31
Smyrna, ga
Short and long air packs are defiantly interchangeable on a deuce , ferro let me borrow his ( thanks again) at the GA ralley
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
He is talking about using deuce parts on a 5ton. It doesn't really have anything to do with deuce parts being interchangeable
Robo McDuff
1,611
Czech Republic
From the 2014 GA Rally buy/sell thread
Robo,
I have an air pack off a M5x 5-ton (68' multifuel tractor truck), not sure if it was an A1 or A2, I can say it had the 'newer' style steering system on it (like the M939 trucks). The brakes did work on it, so I assume the air pack was functioning.
$50 delivered to GA sound good?
My memory on this is a bit hazy, but CBR Metalworks was supposed to bring a 5-ton Air Pack to the rally. In the end, the only thing he had with him was the Deuce one. I knew from the beginning that it was a Deuce AP, but he or somebody else told me that the long Deuce and the 5-ton were interchangeable. So I took it anyway.
I see that he is banned from the site now.
Is there a way to check an air pack if the seals between hydraulic and air sections are leaking (that is, oil in air section) without removing and opening the entire air pack? I lost about 15 ounces in the time the truck was standing still outside. It has been mostly standing still for 5 years anyway, so better get the whole thing out.
gimpyrobb
27,791
791
Cincy Ohio
Honestly, I wouldn't chance it. You could figure out the volume each unit pushes by measuring the bores on each one, but Id bet there is a reason the 5ton is different than the deuce.
Robo McDuff
1,611
Czech Republic
So I have got a used Deuce air pack to sell at the next GA Rally rofl
Nice way to balance my suitcase for the things I want to take back. :beer:
Managed to take off the air pack today, tomorrow will start take it apart. Should have done it five years ago in the Netherlands, but was too busy and did not know enough about these trucks to tackle it. Now I still don't know enough, but just tackle those problem when they arise.
