Olds engine in CUCV?
fal_shooter
Post Falls, ID
I am having some work done on my CUCV and they said I have an Olds engine in my Chevy. Does that sound right to you? I got it directly from the military so I know it's all original. Any difference in the engines or were they blowing more smoke than my truck?
flighht2k5
Banned
322
Didn't Detroit make the engine? Not gm? Gm made a diesel made from I think an olds or Buick engine in the early 80s. But that was 5.7 liters.
Jeremiah_Johnson
Blairsville, GA
That is a command misconception, Oldsmobile used 350ci 5.7 L chevrolet blocks in some of there cars they were considered Junk by almost ever one who drove one . Your CUCV if stock will have the J code Non emissions 6.2 L Detroit diesel . A big difference between the two engines. As ( Dstang97 ) said you might should go get your truck!!!
11Echo
92
CT W. R.
The 6.2 diesel has nothing at all to do with the earlier 5.7 diesel which was derived from an Oldsmobile 350. I would not want anyone that thought the CUCV 6.2 motor was an Olds engine near it.
Gun Goober
Claremore, Ok
All of you are some what coprrect. Detroit Diesel is, or was, was a subsidiary of GM until about 2002 when GM started buying diesel engines from Isuzu.
In the late 70's and early 80's GM repurposed several gas engines to diesel including Olds, Pontiac, Buick, and Chevrolet. I would think that any one of those engines could be found in military vehicles of that period.
jaymcb
I can speak from personal experience that the olds 5.7 diesel was gawdawful., at least in the olds cutlass I owned.
I don't think someone who can't see the difference between the 5.7 and 6.2 should be doing much to your truck beyond setting tire pressures.
IdahoPlowboy
13
Ririe Idaho
As has been already said get your truck far away from that shop and mechanic. The 5.7 was installed in pickups in the very early 80s and if this shops mech doesnt know the difference then he will mess it up.
dstang97
30
Clover, SC
Nope and your dates are off.
ajsmith184
Howell, Mi
:???: Ive only had my m1009 for 3 weeks and already Ive gotten in 3 debates with people that the 6.2 isnt a gas engine converted to diesel. I think I might print the info out and just keep it in my glovebox just so I dont get angry haha :deadhorse:
spicergear
27
Millerstown, PA
Lol. Turn around and get your truck back.
Seriously, do this. :ditto::ditto::ditto::ditto:
Find a shop that not speculating, guessing, or diesel jaded already...oh, and most importantly: that know what they're talking about. Wanna know for sure- look at the bellhousing pattern. You'd either have an adapter plate, or the BOP TH400.
Barrman
1,777
Giddings, Texas
It might be worth your time to buy this "book":
The Diesel Page, 6.2L Diesel Volume I
I say book, but it is really just a compilation of post/ tech articles from that web site. Very, very informative and accurate post, but it isn't really a book. I have bought both the 6.2 books and feel it was money well spent.
As written above, get your truck away from those people. Probably be a good idea to download the free manuals from this site and do the work yourself.
1,808
The 6.2 is a GM engine no doubt. Detroit did the design work on it. t was introduced in the truck line in 1982 and that series of diesels was the only one used in GM light duty trucks until the Duramax came out. Nothng gas about it at all. As far as the Olds based engines, they were not "converted" gassers. The block was cast as a diesel from the onset. They dd share virtually every dmension from the gas engines at that time and shared some interchangability. I wouldn't wan't anyone fooling with my stuff that wasn't somehwat familiar with what it was. They might want to change sparkplugs on it.
479
Madison, WI
Yeah, they basically used the general small block B.O.P. design, used higher nickle content casting, and added extra block strength, stronger rotating assembly, and different heads. You can convert the 350 diesels back to a really strong gas 350.
As for the shop/mechanic... I'd high tail it out of there, and never go back.
1,178
The LF9 was a 350 cu in (5,737 cc) diesel V8 produced from 1978-1985.
11Echo
92
CT W. R.
GM and Isuzu has had a very long working relationship as GM has held much of their stock over the years. I recall when GM hired their engineers to help design the Duramax line. The motor is built in Moraine, Ohio, near Dayton. GM owns 60% of the 6.6 litre Duramax venture. It never was an Isuzu engine, GM used their engineers to help design it.
Duramax engine assembled in Moraine
wayne pick
Valley Cottage NY
Ah No, Detroit Diesel was not a subsidiary of GM. Detroit Diesel, Allison, Terex EMD, Delco, Munce, Rochester, Fridgedare were divisions of GMC. If anything, Isuzu could be considerd a subsidiary of GMC as they jointy produced light and medium duty trucks since the late 70s. The Chevy luv was an Isuzu pup that was later developed by GM into the S series trucks. The history of DD goes back to the days of WWII as GM was contracted by the US GOV to produce a high performance two cycle marine engine for various types of landing craft. I do not know of any repurposed gas engines other than the 4 bolt 350 conversion and highly doubt the military would use this engine as it was unproven and ultimetly a failure.
ODdave
40
lansing michigan
As said there was NOT a revamped gas engine. The 5.7 diesel shared manny of the same dimentions as the 350 OLDS (NOT CHEVY). The 5.7 diesel used a much thicker casting block, (DX is cast into the sides) with big block sized mains (3in not 2.5 like the gasser) Much larger rods and 1in wrist pins. About the only thing it is good for though is making a pretty neet large ci small block. I used the rods and pistons out of one to biuld a high comp 350 gasser, Worked well and was cheap.
