- 5,568
- 2,841
- 113
- Metairie/La (N'awlins)
I have 2 light switches off a m936 parts wrecker that are on/off switches for the convoy light beacons and for the floodlights.
I am trying to wire them up to use. The back rubber housing has 4 wiring connectors. They have no numbers or markings except 2 have ribbed lines and 2 are smooth. See the pictures.
I assume they ground through the mounting.
Which side is the hot supply side and can only one wire be used? lined ribbed side or smooth?
The other side would be 2 hot switched feeds when turned "on"?
Thanks for your help!
