only smoking downhill
Kgood
Cumberland maryland
I'm confused on my 37'. She runs fine uphill, on flats. She idles fine on flats and uphill. But if the truck is idling on a downhill slope, she outperforms a steam engine on the amount of cloud cover in the area. Appears to be oil, smells like it. Thought it was the oil bath but after checking the goose neck drain valve, its dry. Any thoughts would be appreciated
mcmullag
13
Colorado Springs, CO region
What he said. With the throttle plate closed, the intake stroke suction is pulling air past the valves, sucking air from the oil sump area.
On an overhead valve engine ohv you can sometimes get by with replacing the cup shaped rubber seals on the valve stems but on a flat head, I don't know what the valves have on them if anything to help stop this oil vapor from going down along the valve stems, or up, in this case.
NDT
6,182
Camp Wood/LC, TX
I think your problem is related to the vacuum pump. Disconnect the line between it and the intake manifold and see what happens.
